Radiator replacement
Old Jan 9, 2011 | 03:54 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default Radiator replacement
Hows it goin, my radiator is leaking real bad and I need to replace it. It looks simple by the factory repair manual, I have a few questions about the transmission lines that go to it. What is the easiest way to remove them? I only have simple hand tools and money is tight so i cant afford to buy new tools, and how much atf4 would i loose from removing them? And does anybody have any experience with the radiators from orileys or auto zone? Thanks fro the help
Old Jan 9, 2011 | 10:39 AM
Not too bad of a job. You WILL need the special tool to disconnect the trans line though. You can get the cheap plastic guys for a couple bucks. (Do NOT get the plastic multi tool though, it will not fit in the space available....) You might be able to borrow/rent one from the parts store.
Shouldn't lose more than a quart of trans fluid.
No idea on the quality of aftermarket radiators..... what kind of warranty do they come with?
I wouldn't buy anything from autozone....... I have had bad experiences with their parts. But, that's just me.
Old Jan 9, 2011 | 10:40 AM
lazyboy's Avatar
lazyboy
orileys in mine for about a month now. no probs yet. have a stick so cant tell you much about the auto but usually takes an open end wrench. bag the line ends real tite when you disconect (keeps dirt out and should limit drain). cant imagine it would even take a quart to top off when done.
pretty easy job but take your time puting the new one in, the last thing you want to do is ding it up.
Doug
Old Jan 9, 2011 | 10:43 AM
lazyboy's Avatar
lazyboy
scratch that open end wrench guess. heyyou was typing at the same time and is in the know.
doug
Old Jan 9, 2011 | 12:01 PM
Zeppelinrocks
Ok thanks for the help, is the tool just a quick disconnect? If so what size do I need and where do I disconnect from I found out midnight last night and have to go to work now.. And from oriley and autozone come with a limited lifetime warranty
Old Jan 9, 2011 | 12:12 PM
BIGBIRD85's Avatar
BIGBIRD85
http://www.autozone.com/autozone/acc...ifier=2356_0_0_
you have to have this tool to remove the lower transmission line. the radiator is easy enough. i also suggest you remove the check valve on the bottom line as you replace the radiator.
https://dodgeforum.com/forum/2nd-gen...smissions.html
