Programmer Questions
Old Mar 31, 2011 | 09:47 AM
  #41
Cornerstone1986's Avatar
Cornerstone1986
Originally Posted by RamSport97
Have you verified that your intake manifold plenum gasket isn't toast?
Have not verified this yet but that seems to be the first place to start after talking with some other owners. I'll check it out and post the results. Any idea for the best place to purchase the Hughes Gasket Kit as well as detailed intructions for replacing it? I looked at their website but I didn't know if there was another place that might sell them? I checked out RockAuto.com but it looks like no luck there.
Old Mar 31, 2011 | 07:52 PM
  #42
RamSport97's Avatar
RamSport97
APS also makes a kit
http://www.apsprecision.com/billetplenum.html
But most of us run the Hughes kit. It's very simple, most on here advise not to use the gasket they supply, and run the fel-pro gasket kit from your local parts store. Get your self a Haynes manual, it will pretty much walk you through it with ease. However, if you do follow the haynes route, you don't need to remove the fuel injector's or fuel rails. Also be sure to pickup an intake manifold bolt set, as the stock intake manifold bolts can only be used once as they are Torque to Yield.
Hope this helps.
Old Apr 1, 2011 | 05:41 PM
  #43
hbarker's Avatar
hbarker
Really? ,If have to buy the gaskets from parts store and toss the ones that come with the kit.., can you buy the plate from hughes without the gasket?> heck Im on a budget LOL
Old Apr 1, 2011 | 05:48 PM
  #44
zman17's Avatar
zman17
Retired Moderator - RIP
Call and ask them.
Old Apr 7, 2011 | 08:41 PM
  #45
simple jack's Avatar
simple jack
so all you have to do is order it and when it comes in is plug it in, and it will walk you thru what to do?
Old Apr 7, 2011 | 08:42 PM
  #46
simple jack
the sct that is
Old Apr 7, 2011 | 08:59 PM
  #47
RamSport97's Avatar
RamSport97
Yes sir you got it. And lmfao at your screen name.
Old Apr 8, 2011 | 01:53 PM
  #48
simple jack
vie been told that im not the sharpest tool in the shed, nor the brightest bulb on the tree. it shall be ordered soon. thanks
Old Apr 8, 2011 | 02:08 PM
  #49
simple jack
which one do i order? theres bunches of them. see why i got my name?
Old Apr 8, 2011 | 07:38 PM
  #50
jasonw's Avatar
jasonw
Site Moderator
Email hemifever@aol.com, his name is Sean. He will set you up.
