HELP!!! 1999 dodge ram 2500 5.9L LEAKING FROM TRANSFERCASE AND REAREND
Old 01-13-2011, 02:22 PM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
That's a lot of leaks for a truck with only 84,000 on the odometer. I'm wondering if the truck was wrecked, or if it sat unused for an extended period. It seems that one or the other must be true to induce so many leaks in so many places.
Old 01-13-2011, 08:02 PM
black99ram2500's Avatar
black99ram2500
black99ram2500 is offline
truck has never been in an accident, the truck has been in New Hampshire its whole life besides as of now im assuming the salty roads caused the seals to screw up? besides that the truck is pretty much mint
Old 01-13-2011, 08:12 PM
VEETEN's Avatar
VEETEN
VEETEN is offline
Well let's try to keep it wreck free and check and possibly change the main brake line running above the gas tank.
Just a heads up for you, they love to rust and fail.
Old 01-13-2011, 08:29 PM
J415's Avatar
J415
J415 is offline
That all depends on where you live. I live in the San Francisco Bay Area and I don't have a spot of rust on my '97
Old 01-13-2011, 09:12 PM
VEETEN's Avatar
VEETEN
VEETEN is offline
he said it's been in New Hampshire it's whole life. So it probably looks like mine from underneath. LOL
Old 01-16-2011, 09:32 AM
black99ram2500
haha i will get some pics up today, the interior had an inch of dust on it so it must have sat but it has some surface rust on the frame nothing major
Old 01-16-2011, 04:40 PM
UnregisteredUser
That would explain it. Vehicles that haven't moved tend to develop leaks. They also develop crud in the engine top end, rust pitting on engine bearing surfaces, sticky valves, rust on the portions of the ring/pinion gears that were not submerged in oil, decomposed automatic transmission clutches, and all kinds of dry seal problems like the ones you're seeing.
Quick Reply: HELP!!! 1999 dodge ram 2500 5.9L LEAKING FROM TRANSFERCASE AND REAREND
