problems installing airgap ! :/
Old Jan 12, 2011 | 01:18 AM
lastrights's Avatar
lastrights
Default problems installing airgap ! :/
broke a bolt on the right side by the thermostat 1st bolt , has no head on it what do i need too do ? there nothing to grab onto . any ideas im in a bind and need to get it fixed ASAP
Old Jan 12, 2011 | 01:27 AM
shanec706's Avatar
shanec706
ive never taken the intake off of a dodge motor, but i HAVE had this problem with a small block ford. remove take the intake and extract the broken bolt with a pair of visegrips. hope this helps.
Old Jan 12, 2011 | 01:33 AM
lastrights's Avatar
lastrights
no head on bolt to grab with vise grips or anyhting like that
Old Jan 12, 2011 | 01:34 AM
Salex007's Avatar
Salex007
he has nothing to grab onto, id try to drill into bolt and then try to reverse it back out
Old Jan 12, 2011 | 01:40 AM
shanec706's Avatar
shanec706
what i mean is if the intake will come off with the bolt still in, remove it. there will be enough in the bolt standing there to grab on to with the visegrips then.
Old Jan 12, 2011 | 01:53 AM
crazzywolfie's Avatar
crazzywolfie
it might be possible to weld a nut onto what is left of the bolt if you have a welder.
Old Jan 12, 2011 | 02:05 AM
J415's Avatar
J415
I had that happen to me and what worked for me was to soak it with WD 40. Then with the left handed drill bit drill in to it and it came out (Lessens the tension).
Old Jan 12, 2011 | 02:42 AM
offroadjosh's Avatar
offroadjosh
Easy out???
Old Jan 12, 2011 | 06:59 AM
dhvaughan's Avatar
dhvaughan
drill out the center of the broken bolt and then use an ease out. be very careful not to break the drill bit as that just makes it a lot worse. start with a 1/8 or slightly smalller and then try the ease out but don't break it either. if it doesn't want to come out then use a bigger bit and drill a larger center and use a larger ease out.
Old Jan 12, 2011 | 08:46 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Pb blaster!!!!
