If it's a crossover toolbox (the kind that sits on the bed rails) you can use either j-bolts or just drill through the box into the bed rail and bolt it down. I secured mine with j-bolts that I covered with some stout vinyl hose.
I was hoping that wouldnt happen, how do you delete it?
I haven't figured out how to delete posts, maybe someone else can chime in. I only found it because I replied to your other post and then came in this one and didn't see my post.
Probably because you have two identical posts going.
Originally Posted by MedicNathan
They stay pretty well with just friction. You said it slid right off your old one....
Some tool boxes will have a hook or two to help them hang on, but metal on metal has a rather high static friction, especially if you load your tool box up. and unless your trying to off road with a tool box...
Well when i put the box on my new one, it really did slide right off. It woldnt be safe to drive it if not attacted.
Like it said i would just bold it down if the other side could open..
