Rear Diff Fill Plug??
Old Jan 16, 2011 | 05:16 PM
captaincasey123's Avatar
captaincasey123
Question Rear Diff Fill Plug??
95 ram 1500 2wd 5 speed just filled the trans with gear oil wanna drain the diff and refill it while i've got that nasty crap out. Can't find a fill plug tho and don't want to drain it till i know how to fill it. Thanks in advance Casey.
Old Jan 16, 2011 | 05:29 PM
Silver_Dodge's Avatar
Silver_Dodge
To drain the diffs, you remove the cover and let it drail out. To fill the diff, install the cover and fill to the bottom of the fill hole (the only hole on the diff cover assuming you have stock diff covers).
Old Jan 16, 2011 | 05:44 PM
dhvaughan's Avatar
dhvaughan
fill plug for the rear diff is on the rear side, its a rubber plug about 2/3 of the way up the cover.
unlike a well thought out toyota rear end with a drain plug in the bottom, we have no drain.
Old Jan 16, 2011 | 06:11 PM
TheBigRedOne's Avatar
TheBigRedOne
Crack the case open and drain that way. Refill through the fillport.
