Trans ???
Old Jan 19, 2011 | 10:44 AM
Shellys4x4's Avatar
Shellys4x4
Oh... Lol
I've been driving it with the 4 gears and I do 70+ on the hwy and the rpms stay below the 3
Old Jan 19, 2011 | 10:48 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^If you have a manual, it is a 5 speed. Which means you have been driving with only 4 gears.
I posted the thing about the 46RE cause I am getting into an argument. It is unrelated to the problem at hand.
Old Jan 19, 2011 | 10:49 AM
Shellys4x4's Avatar
Shellys4x4
Okay thanks
Old Jan 19, 2011 | 11:03 AM
matty675's Avatar
matty675
yes, excuse me you are correct.
try not to get so worked up next time
Old Jan 19, 2011 | 01:39 PM
candymancan's Avatar
candymancan
Wow ok i havent read the entire thread but like 4-5 of you guys are really wrong on this...
The Automatic transmissions in the dodge was the same used in the Jeeps in these years. Its 4 speed automatic with overdrive... Meaning 4th gear is overdrive... There is no 5th gear. The 5th gear you guys are fealing on your trucks is the torque converter locking up... lol if your so called 5th gear (aka torque convertor) isnt engaging (aka locking) then its probably your torque converter that is going bad or is bad.
I always made this mistake also, calling the torque converter a 5th gear. I relise the thread maker said he has the 5 speed manual but some of you guys said the automatic was a 5 speed also and its not
Old Jan 19, 2011 | 03:47 PM
dodge dude94
Yes, I understand this.
The poster has a 5 speed MANUAL.
Are you speaking of the manual or the automatic?
Old Jan 19, 2011 | 03:56 PM
dodgetrucker75's Avatar
dodgetrucker75
5th gear is a known issue with the nv4500 manual trans, but its actually a very easy fix, what happens is there is a nut that holds the 5th gear on, and it will loosen and allow the gear to slide back on the shaft, just need to pull the rear housing on the trans and put the nut back on, with the use of locktight, or double nut, tack weld, ect...
