Ebay 50mm throttle bodies
Old 01-20-2011 | 09:19 AM
Sheriff420's Avatar
Sheriff420
I used a milling machine on mine.
A drill press with a brake cylinder hone mounted in it on low speed would probably work.
A lathe might work if you mounted the throttle body in the tail stock somehow and your tool bit in the chuck.
Old 01-20-2011 | 10:59 AM
dodgeram07's Avatar
dodgeram07
Originally Posted by shanec706
how did you bore the TB out? and what kind of gains did you see after installation?
stock bore is 50mm.. but it tapper down to about 47 above the tb plates
gains,, for me right off the bat
Old 01-20-2011 | 11:43 AM
Salex007's Avatar
Salex007
same gains right off the bat, throttle response is much quicker
Old 01-20-2011 | 12:09 PM
diedinabox's Avatar
diedinabox
I installed one that I bought got few more hp but when I put a spacer with it big difference... Fuel mileage actually went up .75 mpg lol but throttle responce is much much better ...
Old 01-20-2011 | 12:56 PM
Salex007's Avatar
Salex007
you thought the spacer did something but it didnt at all unless you drive lightly now
Old 01-20-2011 | 01:03 PM
Throttle body spacers don't do a damn thing on our trucks. Waste of time, money, and hood clearance.
Old 01-20-2011 | 01:15 PM
lastrights's Avatar
lastrights
actually i noticed a gain in power when i took mine off lol
Old 01-20-2011 | 01:19 PM
jasonw's Avatar
jasonw
Site Moderator
Yup, TB spacers are just paperweights. On older TB injected vehicles, they would help a lot of the time. However, our trucks are port injected, so all a TB spacer does is delay the air from getting into the intake manifold by an extra millisecond. That has no positive effect whatsoever on the truck, sometimes even having an adverse effect on performance.
Old 01-20-2011 | 01:30 PM
diedinabox's Avatar
diedinabox
Hmm ok well I just so happen to have a dyno program "Dyno scanby auterra" and also "Nology Lap dyno" on my lap top ... I will "weather permitting" post sheets on here with and with out right or wrong with old tb and with new. We'll see what is actually right if its worth it or not.
Old 01-20-2011 | 01:52 PM
95 Jamin Ram's Avatar
95 Jamin Ram
Originally Posted by dodgeram07
you may have a little problem with you around air cleaner siding around
I ended up taking that off and putting the stock one back on it felt much better
Quick Reply: Ebay 50mm throttle bodies
