y-pipe install, space out O2 sensor?
Old Feb 3, 2011 | 09:28 PM
dhvaughan's Avatar
dhvaughan
which O2 sensor are you talking about?
you want the front O2 sensor to be directly in the exhaust stream so the PCM gets a good read on the exhaust gas. so don't space out the front O2.
do whatever you want to on the rear O2. i'd leave it alone and only change it if does throw a code. if it ain't broke don't fix it.
Old Mar 16, 2011 | 08:17 AM
champion88's Avatar
champion88
Originally Posted by 98BIGRED5.9Gas
what jegs y-pipe did you use?
I used the Jegs 555-31020 y-pipe. But honestly I wasn't impressed with the design for the money. One thing I didn't like was the joint where the two sides come together instead of swelling one piece to fit over the other they reduced it to fit inside the other, I felt this created less flow. I'm thinking about cutting that out and redoing it. Also maybe it was the headers that I used, but it just didn't fit like it should have, for the money spent I'd been better off taking it to a muffer shop.
Old Mar 16, 2011 | 08:44 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You want the pipe reduced like that in the direction of flow. It helps with leaking when just being clamped. And that little bit isn't restricting squat anyway.
Old Mar 16, 2011 | 12:44 PM
99dodge318's Avatar
99dodge318
that little restriction you speak of champion isnt anything compared to the restrictions for the stock y-pipe/cat
