99 dodge ram front end problems
Old Jan 19, 2011 | 05:58 PM
95RAM360's Avatar
95RAM360
could the trac bar cause hopping when turning? this problem has once again arised in my ram....
Old Jan 19, 2011 | 06:17 PM
Shouldn't..... What did you do to fix it last time? Sounds more to me like a bad u-joint.
Old Jan 19, 2011 | 06:41 PM
black99ram2500's Avatar
black99ram2500
what about the steering stabilizer? should i replace that also
Old Jan 19, 2011 | 08:12 PM
deathwatch789's Avatar
deathwatch789
I have the same problem with my 01 dodge ram 4x4 it shakes around 55 mph pretty bad is it the trac bar for me also?
Old Jan 19, 2011 | 08:16 PM
J415's Avatar
J415
Just throwing this out there. When ever I'd hit a pot hole or bump on the freeway, my rig would shimmy from side to side horribly. It turned out that my ball joints were shot. I replaced those with some XRF ball joints and now it's solid as a rock. Just food for thought.
Old Jan 19, 2011 | 08:43 PM
black99ram2500
yea i was thinking the ball joints needed to be replaced and i had a garage tell me they were fine and they looked new, so im assuming its the trac bar
Old Jan 19, 2011 | 10:42 PM
xxxRedneck93xxx's Avatar
xxxRedneck93xxx
thats definitley the track bar. have your alignment checked after you install the new one.
Old Jan 19, 2011 | 10:43 PM
xxxRedneck93xxx
most likely. have all your ball joints checked as well.
Old Jan 20, 2011 | 09:05 AM
wv ram's Avatar
wv ram
Default front end
sounds like the death wobble , i had similar i believe genos garage had a tech article about front end alingment specs , that are different from what the shops say is right , changed mine to the new specs and feels like a whole different vehicle ,my guy that does front ends now uses it for all the 2nd generation dodges . i think if i remember it the camber that is the problem
Old Jan 20, 2011 | 06:45 PM
rtaylor's Avatar
rtaylor
Default wobble
I had the very same issue, some moron put car/light truck tires on my 2500 heavy 3/4 and every time I hit a hole or bump'd a place in the pavement on the interstate the front would shake out of my hand!!!!! I put some BFGs 285-75-16s and its never happened again. Hopes this helps ya out.
