speedometer
Old Jan 19, 2011 | 10:54 PM
vkandel's Avatar
vkandel
Default speedometer
Is there any tricks on getting my speedometer working again
Old Feb 4, 2011 | 10:51 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
BUMP...was in the wrong section and missed.
Old Feb 4, 2011 | 11:04 AM
dodgeboy1979's Avatar
dodgeboy1979
give us a little insite to any syptoms, things you have noticed etc...with your speedo and people may be able to help you.
Old Feb 4, 2011 | 02:26 PM
Silver_Dodge's Avatar
Silver_Dodge
Do you also happen to have the brake and ABS light on? If so, it's the sensor or connection to the sensor that is on your rear axle on the forward facing side of the differential.
Old Feb 5, 2011 | 10:41 AM
outlaw93z's Avatar
outlaw93z
Like the person before me said, it can be the rear speed sensor on the axel. It causes a bunch of problems over time and it can cause failure of a speedometer. Happened on my truck, and when I pulled the sensor plug, it was full of salt. Figures.
Old Feb 5, 2011 | 11:41 AM
dhvaughan's Avatar
dhvaughan
on my 01 the speedometer, (and sometime the tach) will not work after the truck sits in the hot summer sun all day.
the first time it did this in 06, i changed out the rear sensor, then the speed sensor in the trans. no help. then i swapped the cluster with one from junkyard and it fixed it.
it started doing it again with the new cluster in 09, and i found that if it tapped firmly on the speedo lens, right in the center, it would unstick and work.
