fuel pump problems
Old Jan 20, 2011 | 07:01 PM
chardy86's Avatar
chardy86
Default fuel pump problems
I have a 96 ram 4x4 with a 5.9 in it, today i put a new fuel pump in it and still no crank, I have ohmed out the fuses and relays they all seem good. What else could be wrong. I feel like its not getting power bc i changed the tank slap full of gas and when i turn the key the fuel level should go all the way up, but it doesnt PLEASE HELP thanx
Old Jan 20, 2011 | 07:30 PM
I think you wasted money on the fuel pump....
Open the hood, pull the cover off of the PDC (power distribution center, black box right behind the battery) and swap the asd relay with the wiper relay. See if anything new and different happens.
Old Jan 20, 2011 | 07:41 PM
chardy86's Avatar
chardy86
i have tried swapping the relays to no prevail, Also the last time the dodge ran i was jumping off my wifes vehicle i wonder if i might have gotten a problem from that like maybe through the dist., but that still doesnt explain the gas gauge, which has never worked, tomorrow i will check to see if i have fire
Old Jan 20, 2011 | 08:00 PM
Do the other gauges work?
Need to find out what you are missing, spark, or fuel.
Old Jan 20, 2011 | 08:08 PM
chardy86's Avatar
chardy86
yes the other gauges work, when changing the old pump i noticed that the board for the float looked burnt, or worn out over time so i thought the new pump assembly should work, another thing i cant hear the pump come on, can you usually hear the pumps or are they usually quiet, i have never paid attention to it before, I can however hear the relay click on after i turn the key
Old Jan 20, 2011 | 08:12 PM
If I am standing next to the gas cap, with the cap off.... and someone else turning the key, I can hear it. But, my hearing isn't the best anyway..... Grab a friend, have them turn the key while you listen. See what happens.
Did you try swapping the fuel pump relay as well?
Old Jan 20, 2011 | 08:16 PM
chardy86's Avatar
chardy86
i was laying under the truck and couldnt hear it when my brother turned the key, but my hearing isnt all that great either, i will have to check againg tomorrow thanx for the fast replies.
Old Jan 20, 2011 | 08:18 PM
dhvaughan's Avatar
dhvaughan
at ignition on, the pump should come on for 3 seconds? or so, then turn off if there is no engine-rrunning signal from the crank position sensor. it should make a whining noise that you can hear. the right way to check the fuel pump is to check pressure at the rail with a gauge. should be about 49 psi. a low tech way is to depress the schrader valve and if fuel squirts out at 49 psi and hits you in the eyeball, then its good. cover the port with a rag, catch any spill, do not smoke!!!
there is a MAIN fuse in there somewhere. might be called fusible link. also an IOD that's important.
Old Jan 20, 2011 | 08:24 PM
chardy86's Avatar
chardy86
i was told about this valve i depressed the valve with a ink pen i did not get any fuel just some air
Old Jan 20, 2011 | 08:37 PM
cycle the key a couple times, and try again.
