So... Did my ect just eat itself?
Old Jan 22, 2011 | 12:48 AM
Mad_Scientist's Avatar
Mad_Scientist
Question So... Did my ect just eat itself?
A little background: 2 days ago, i got a p1281-engine taking too long to warm up. Under the assumption that the stat was stuck open, i went ahead and replaced it.
Heres the fun part- after replacing the stat and waiting for the rtv to dry, I started it, and BAM cel comes on within 3 seconds. Drive for another 5 or so seconds and my check gauges light pops up. Look down at temp, and its sittin at 260, another 5 seconds and it whips back to all the way cold.
Parked the truck and checked the code by cycling the key 3 times (love being able to do that). Po118-ECT voltage too high. I'm wondering if my ECT just fried itself, or if the problem is simply because i didnt top off the rad after completing the stat job (didnt have any coolant, and only had to drive a block to my house). Wont be able to update until afternoon tomorrow
any advice or opinion is appreciated
Mad_Sci
Old Jan 22, 2011 | 04:14 AM
UnregisteredUser's Avatar
UnregisteredUser
Air (way too much of it) in the system will cause the symptom you saw on the temp gauge.
The code is usually a bad temp sensor or a wiring fault.
Old Jan 22, 2011 | 03:02 PM
Mad_Scientist
^^^^thinkin its the second option, thanks for the reply.
New and interesting development: topped off the coolant and reset pcm before i went to help my brother out. Truck started and ran fine on the way there, temp gauge acted normal.
As i went to leave, it hiccoped once like it wanted to die when i switched from reverse to drive, then popped back up to normal idle. About 2 blocks later, it died when i slowed down to take a turn. Had to pump the gas a bunch to get it to start back up.
I parked at a gas station and popped the hood to see if it was something obvious, but nothing was out of the ordinary. Started fine when i left the gas station, after 2-3 more blocks, it gave me the same problem stated in op (temp gauge went nuts, CEL came on-po118).
Pulled in to advance to try and pick up an ECT, and it died when i put it in park. Had to pump the gas to start it, drove fine all the way home (2-3 miles), temp gauge read fine. Tested to see if changing gears was the problem: put it in park, stayed at good idle no hiccup or anything.
At this point Im thinking its a short in the wiring to the ECT: while driving the wires bounce up and down and short, giving false info to the PCM making it think the engine is hotter than it actually is and it meters A/F ratio as if it was at operating temp, while it should actually still be in open loop
Anyone else have ideas? C'mon guys I need some more opinions. Thanks in advance
Mad_Sci
Old Jan 22, 2011 | 03:09 PM
I would check the connector at the sensor. I don't know if resistance goes up as temp goes down, or vice versa, but, if the PCM suddenly saw the temp going to -40..... it would dramatically alter the amount of fuel it was dumping, and you would have all sorts of interesting issues. (like you are seeing.....)
Old Jan 22, 2011 | 03:18 PM
Mad_Scientist
Thanks for the quick reply HeyYou, thats exactly what i was thinking. Waiting for it to cool down a bit, then i get to whip out the old volt meter and see whats up.
Probably disturbed the wiring when i took off the alt (stat housing still had that damn tab on it, so i couldnt just pull it up) for the stat replacement.
Old Jan 22, 2011 | 03:21 PM
Bring it up here, its colder than a witches tit in a brass bra..... My truck goes from fully warmed to stone cold in less than 20 minutes.....
Old Jan 22, 2011 | 03:25 PM
Mad_Scientist
LOL Thats why im glad i live in the south, id rather sweat my ***** off in 105 deg 99% humidity heat than to be cold. Must be pretty cold up there if it cools that quickly (to think i was bitchin this morning when it was 32 out... its 60 now, feels great [icon_mrgreen])
Old Jan 22, 2011 | 04:21 PM
Mad_Scientist
Got her fixed: before diving in with the voltmeter, i took the pigtail to the sensor and wiggled it and the wires to it around a bit. Pushed it back down onto the ECT, and went for a short drive. lo and behold: CEL went bye-bye. This is just a temp fix, Ill pick up and install a new pigtail for good measure next time im near a pick-a-part.
Wish every problem was this easy lol
thanks
Mad_Sci
Old Jan 22, 2011 | 04:48 PM
UnregisteredUser
Good find! Glad you got it figured out.
