Misfires!
Old Jan 26, 2011 | 11:48 AM
  #21
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by eggie329
It has 135,000. A mechanic friend went through a compression test and checked the plenum. Tuneup parts have about 5000 miles on them. Everyone seems to be stumped as to why it dosen't constantly misfire and only sometimes. Thanks
Was this a cylinder compression test or a catalytic converter pressure test?
Old Jan 26, 2011 | 11:50 AM
  #22
eggie329's Avatar
eggie329
With the plenum would it constantly misfire or just at times (as in my case)?
Old Jan 26, 2011 | 11:53 AM
  #23
Depends on what mood the engine is in at the time....... not precisely consistent.
Old Jan 26, 2011 | 11:55 AM
  #24
eggie329's Avatar
eggie329
Yeah its completely random. It's been running perfect for about a week and for about 45 minutes today and all of a sudden its blasting fireball out of the muffler!
Old Jan 26, 2011 | 11:57 AM
  #25
Could be a failing sensor.... Crank Position, Cam Position, O2...... Trouble with that is, I have no idea how to test. You would need to be able to do some data logging, and then compare various sensor inputs between when it was running good, and when it wasn't.
Get any spark knock? Excessive oil consumption? Fouled plugs?
Old Jan 26, 2011 | 11:58 AM
  #26
Gary-L's Avatar
Gary-L
Veteran: Navy
CKP (Camshaft) sensor could be cracked or an issue with the pigtail. That'll cause misfires.
Old Jan 26, 2011 | 12:02 PM
  #27
eggie329's Avatar
eggie329
Yup it burns oil, especially lately. It also uses coolant at times.
Old Jan 26, 2011 | 12:09 PM
  #28
eggie329's Avatar
eggie329
I should also mention it makes a hissing sound when it starts to run funny if it is just idling. Sound come from the passenger side of the engine.
Old Jan 26, 2011 | 12:11 PM
  #29
Take another look at the plenum.
Old Jan 26, 2011 | 12:21 PM
  #30
eggie329's Avatar
eggie329
Some new developements! I just got off the phone with a friend who insists it's the timing. He is saying the plenum would set off a vacuum sensor and show a code.
