95 4x4 5.2 backfires??
Old Jan 24, 2011 | 01:43 AM
Flipzslick's Avatar
Flipzslick
Default 95 4x4 5.2 backfires??
Hi I just bought a few weeks ago a 95 ram 1500 4x4 w/5.2 auto. It has 133k miles. The guy before me cut off the cat and made it true duels ( when I find a cheap enough one I'm putting the cat back on) but I have no idea what's causing it to cut out/ backfire. It only seems to do it climbing hills and 60%+ throttle. I've read alot about the plenums being bad, could this cause it to do that? I'm planing on putting a air gap on it soon, but just wondering if that is my problem?
No cel, good fuel psi.
Plus. My heater if I'm going uphill or hit the gas switches to defrost then switches back to whatever setting it was on, any clues? Thanks in adv. For any help.
Old Jan 24, 2011 | 01:20 PM
For the vent problem, do a search on "wild vents". Its just a check valve you need to replace. Quick, painless, and easy.
For the misfire..... definitely check the plenum. Also, might wanna inspect your tuneup parts. (plugs/wires/cap/rotor) and see what kind of condition they are in.
Old Jan 24, 2011 | 07:06 PM
Flipzslick's Avatar
Flipzslick
Forgot to add them I replaced the cap and plugs/wires. I still need to replace the rotor though, I could not get it off? But none of that helped.
Old Jan 24, 2011 | 07:50 PM
Sounds a lot like a vacuum leak..... or, the rotor is really bad. It just pushes on there. Of course, it takes a damn crane to get it back off.......
Old Jan 24, 2011 | 09:09 PM
Flipzslick's Avatar
Flipzslick
Ok thanks for the help, I ordering my air gap now, so I guess Ill look it over while it's apart and see if it's fixed when it's done. Hopefully.
Old Jan 24, 2011 | 09:25 PM
Send me one too, would ya?
Old Jan 24, 2011 | 09:29 PM
Flipzslick's Avatar
Flipzslick
Haha, I never thought I'd spend $600 on a intake 
Old Jan 24, 2011 | 09:37 PM
I have this really nice, basically brand spanking new, never been installed Weiand Intake for a PONTIAC V-8 (back when they made their own engines.....) that sells for around 500 and some change, and I couldn't even sell it for 200........
Oh well. Just gotta find the right person I guess.
