Radiator replace turns into plenum...
Old Jan 29, 2011 | 12:26 AM
  #31
Mad_Scientist's Avatar
Mad_Scientist
Originally Posted by aim4squirrels
No, the reason you shouldn't flush a transmission is because it is typically done with a machine that hooks to the dipstick and reverse flushes the fluid, pulling the fluid in the opposite direction of normal flow. This in turn pulls all the junk trapped in the filter up into the valve body and jams up the internals of the VB.
If a trans needed burnt clutch material to act as a friction modifier to function it would:
1. Slip like a mother when it was new
2. Not use a filter as it just collects all that precious clutch material
3. Not have a magnet sunk in the pan for the reasons stated above.
4. Use a type F or other fluid that already has "the grippy stuff" in it.
Shops back flush for one reason. It saves time. They don't have to drop the pan and change the filter, they just reverse the flow and pull the crap right up the VB.
You likely know more about this than me, but i will defend my statement because i believe it to be true:
1. A new tranny doesnt need this modifier because there is enough clutch there for it to engage without added assistance (mine shifted hard and fast for 3 months after my rebuild)
2.The filter traps the larger pieces, but the very fine, particulate matter I am speaking of passes straight through
3.Some of the clutch material is nonmagnetic
4.Chrysler is the sole patent holder of atf+4 and they stand to gain more $$$ from using it exclusively in their trannies. I believe they designed it to use this clutch material as the tranny ages to account for the absence of the "grippy stuff"
Old Jan 29, 2011 | 09:09 AM
  #32
aim4squirrels's Avatar
aim4squirrels
Then I will respectfully disagree and thank you kindly for being civil with your argument.
Old Jan 29, 2011 | 11:26 AM
  #33
When I worked at the dealership, if we had a customer come in for a trans service, we would very pointedly ask how long it had been since they had last done one. For those that answered that they didn't know, or, it had been some very long period of time/mileage, it was standard procedure to warn them that the mere act of doing the service may kill their trans. (just changing out filter and whatever fluid was lost in the process) I watched this happen on several transmission. The old crappy fluid worked acceptably well, but, change out the fluid, and the trans was now slipping...... (GM dealership.)
Flushing the trans does indeed circulate all the crap throughout the trans, and cooler, etc. Doing so on an older trans, that hasn't been well maintained, is pretty much a guarantee of trouble. Just not a good idea.
Old Jan 29, 2011 | 11:38 AM
  #34
aim4squirrels
My understanding of a poorly maintained trans was that the new fluid with its replenished detergent package will loosen deposits and collections of debris and send them flying thru the lines, much like a blood clot thru an artery.
Old Jan 29, 2011 | 11:40 AM
  #35
True. But, much like the human body, there are many possible failure modes that flushing can induce. It is simply a bad idea in general. Unless it is something done on a regular basis anyway. (but, I really don't see any benefit in that.....)
Old Jan 29, 2011 | 12:23 PM
  #36
aim4squirrels
Old Jan 29, 2011 | 01:20 PM
  #37
I have seen it go a buncha different ways. Some failed immediately after the fluid change. (wouldn't work at all after putting them back together.) Others failed within a few miles of the change. Still others were absolutely horrible, and ran another 50K miles before taking a dump.
It is seriously a crap shoot.
