New Mopar perf chip question?
Old Jan 27, 2011 | 03:29 PM
  #21
95Erokram's Avatar
95Erokram
I have had the Mopar performance pcm in my truck since 96 it was installed at the dealer before I drove the truck off the lot. But as for the towing warning, I have towed with this pcm and have had no I’ll effects when towing, You do need to use the best gas you can get with this pcm but it really does not limit you from towing, if anything it helps when towing. The biggest thing I towed for a year was a 28’ 5000lbs 5th wheel. I still tow boats and sleds around with the dodge when the dually is not worth running up. I honestly think the mopar performance pcm is the cats meow for 94-96 trucks yes i am including the 96 model year.
By the way dude. I love that truck. blacks' a good color on these dodges. Nice mods.
Old Jan 27, 2011 | 03:38 PM
  #22
95Erokram's Avatar
95Erokram
Originally Posted by dipsherry
summit has them for 265.xx http://www.summitracing.com/parts/DCC-5249546/ there is not much hope for us 94 95 guys i know i want a tune but i tow ALOT and cant afford to pop a motor or blow a tranny
bro thanks for th link but i drive a 318 to my knowledge and you got a link for the 360. Also checked summit in depth.... no moparpcm from them for my engine. unless you know where they are? thanks for the help though
Old Jan 27, 2011 | 03:57 PM
  #23
merc225hp's Avatar
merc225hp
Thank you. Heres one of many sites that you can get the pcm from.
http://www.mopartsracing.com/parts/ram.html
Old Jan 27, 2011 | 05:05 PM
  #24
Hahns5.2's Avatar
Hahns5.2
I'm using a 5.9 auto PCM with my 5.2 5 speed and it runs great, AFRs are also correct (wideband verified).
Old Jan 27, 2011 | 08:18 PM
  #25
grox's Avatar
grox
That has nothing to do with the Megasquirt?
Old Jan 27, 2011 | 08:39 PM
  #26
Hahns5.2's Avatar
Hahns5.2
I ran just the Mopar PCM for over a year before I put in Megasquirt, the Mopar PCM just controls ignition now.
Old Jan 28, 2011 | 08:33 AM
  #27
grox's Avatar
grox
Hmm. I wonder if there is a difference between the 5.2 computers and the 5.9 computers
Old Jan 28, 2011 | 10:24 AM
  #28
Programming. That's it.
Old Jan 28, 2011 | 10:27 AM
  #29
grox's Avatar
grox
Yes, and what's the difference?
Old Jan 28, 2011 | 10:31 AM
  #30
360 wants more fuel, and probably different spark curves. Aside from that, they are basically the same engine..... use all the same sensors...... and the same wiring harness. Upgrading from a 318 to a 360 is rather simple. For the PCM end of things, all it takes is a re-flash.
