Air gap
EGR is going to be the sticking point. Air Gap has no provision for it, but, I think there are aftermarket kits to install it.... If you don't.... worst thing that happens is you get EGR codes.
You could conceivably get a custom PCM that does not have EGR programmed in, but, thats additional expense..... Finding someone reliable to provide the PCM is also fun..... not sure there are many folks out there in the world that do that trick anymore.
You could get a Mopar M1 intake that has egr provisions and get the Mopar performance PCM. Lots of people say you will lose low end power that will be true if you have a stock motor, but with some other mods to go with the M1 you will make more than the kegger. I don’t care what dyno sheets you see on the web and what they tell you. I really have one and it works great. Also it's very easy to install, no new fuel lines, adapters, nor did i have any clearance problems with my cai.
P5007398AB
2 bbl mpi,aluminum,single plane, magnum direct replacement, w/EGR port 1992-96 5.2/5.9 same height as stock manifold. requires installation kit P5007638
552.00
P5007398AB
552.00
P5249545
Engine Controller (1994–95 5.2L ATX Ram and Dakota)
259.0
259.0
Trending Topics
Ok. I'm really starting to think I might just replace the plenum, My main goal is to get the truck running right,
I called hughes today, and they won't even tell me what the mods are until I buy it, I don't like that at all!
P5007398AB
552.00
552.00
P5249545
259.0
259.0
Just what level of mods are we talking in order to not lose low end? Keep in mind I've been told I can't really do things llike re camming to even a mildly different profile without a computer retune. For example would I lose low end if the extent of my planned mods were the m1 + some HS1.7:1 roller rockers, free flowing exhaust and the mopar pcm?
So you are saying the mopar pcm is allows one to run a m1 with an obd1 truck without otherwise retuning, ie remapping fuel curves to maintain proper mixture? and still have proper jetting for both performance and going through the sniffer test here in WA st.? Would the same also be true of mopar pcm with Airgap plus aformentioned support mods on obd1 triuck?
