Transfer Case questions and t-Case saver
Old Jan 26, 2011 | 08:40 PM
Hostilian's Avatar
Hostilian
Default Transfer Case questions and t-Case saver
So I changed the oil in my T-case the other day and noticed it was leaking around the shaft going to the rear axle and around the front where it connects to the tranny. I got the seals in today and pulled the t-case (Thanks to Sheriff420's DIY) (Thank you sir). While I had the t-case out i noticed that the thing was filthy dirty all over, almost like the silicone gasket in the middle of the cases is leaking as well. I was wondering how hard is it to split the cases on this thing. The service manual didnt make it out to be very hard. Remove the tail housing, take out the bolts holding it together, then split the cases. Is it really that easy? I searched the forums and couldnt find a DIY or anything thing on it. Also the T-case saver, how hard would it be to make one? Me and my father have our own machine shop (laths and milling machines) and all it looks like is pretty much a lock collar fitting around the rear output shaft. Anyone tired to make one before?
Old Jan 26, 2011 | 10:56 PM
Yes, it is indeed that easy.
T-case saver also has a 'lip' that seats into the grove on the shaft. It doesn't seem like it would be that hard to make one, since you have the proper equipment.....
Old Jan 26, 2011 | 11:03 PM
Hahns5.2's Avatar
Hahns5.2
I understand why most people wouldn't want to but when I put a new snap ring on mine I simply tack welded it in place.
