2500 ram front and rear diff
Old Jan 26, 2011 | 09:58 PM
countryboy17's Avatar
countryboy17
Default 2500 ram front and rear diff
I have a 2001ram 1500sport and a 1996 ram 2500 and I was wondering what I would have to change to put the front and rear riffs out of the 96 and swap into the 01 thanks also the 01 already has a 2500/3500 lift kit in it if that helps
Old Jan 26, 2011 | 10:02 PM
olyelr's Avatar
olyelr
So you already changed the rear springs out for 3" wide units? Cause the stock ones are only 2 1/2".
They will basically be bolt on. One issue you may have to play around with is the driveshafts. Also the control arm bushings changed within those years.
Old Jan 26, 2011 | 10:22 PM
countryboy17
No still has 2 1/2 inch springs but the front is done Yea I noticed about the control arms I have a lmc truck book and it offers 2 diff types they have it for 94-99 control arm then they have 00-01control arm So what's the difference and wAt am I going to have to do to make it work
