plenum pan gasket sillycone
Old Jan 28, 2011 | 01:47 AM
99dodge318's Avatar
99dodge318
i personally wouldnt put rtv silicon on the belly pan cause if a piece fell off into your kegger, it would travel all the way through your motor(hopefully).
i did use rtv in between the intake and block.
Old Jan 28, 2011 | 05:57 AM
gdamtbnms's Avatar
gdamtbnms
The IT i was refering too were the instructions that came with my kit they told me exactly what to buy to put on the gasket itself.
Old Jan 28, 2011 | 03:08 PM
PurplDodge's Avatar
PurplDodge
Get the Mopar metal compression gasket. No worries about sealant.
Old Jan 28, 2011 | 08:55 PM
jgcox6's Avatar
jgcox6
Please give me the low down on the gaskets and if I and where I would used the RTV. When i replace the belly pan..do i put RTV or just the fel pro gasket? Do I use it on both sides? Where do I just use a gasket and not RTV?
Old Jan 28, 2011 | 11:22 PM
bekins01ram's Avatar
bekins01ram
Did a buddies a few months back, and is working well so far. Did as a mech. told us to. No RTV between the bellypan & manifold. We just used the metal gasket that came with the hughes bellypan. Applied thread lock and torqued bolts. We lightly used RTV on front and rear seals and sides where manifold sits on block. Especially around the bolt holes. That was it.
Old Jan 29, 2011 | 02:32 AM
4085spd's Avatar
4085spd
When i use to make modded keggers we would dimple the mating surface of the intake. This gives the RTV something to grab hold of. So yes i have used RTV on all intake pans with gasket. It is used as a dressing therefore the direction for it being used as a dressing needs to be followed.
Old Jan 30, 2011 | 06:55 PM
PurplDodge's Avatar
PurplDodge
Yeah, so when the engine goes through a couple thousand heat cycles, the intake expands and rips the RTV, causing a leak. Great idea.
Old Jan 30, 2011 | 07:06 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Next time I remove the plenum, I'm going to have the aluminum pan welded to the intake.
Problem solved.
