Balljoints
Old Jan 28, 2011 | 12:33 AM
Flipzslick's Avatar
Flipzslick
$250 to replace all four, just labor, I already have the BJ's. And it's a 95 4x4 1500. Everywhere else quoted me 500+ w/out parts!
So is it a good deal or just fight with them my self, I'd just have to go out and get jack stands, breaker bar , axle nut socket.....?
Old Jan 28, 2011 | 02:39 AM
CPTAFW163's Avatar
CPTAFW163
you also need a puller.
And if 3 ball joints are bad, you change ALL of them. Not just the bad ones. Same with headlights/tail-lights, you replace both. Same with Armpits, you don't wash just one.
Old Jan 28, 2011 | 04:21 AM
Flipzslick's Avatar
Flipzslick
Lol, yes I plan to replace all 4, the ujoints, breaks, and maybe the hubs, idk if I can afford them though, I'm also tackling the intake this weekend.
Old Jan 28, 2011 | 11:37 AM
dodgeram07's Avatar
dodgeram07
well now that i know it's a 4x4
this may help u
http://www.pavementsucks.com/tech-article-6.html
also this,,,, there is a link on the DIY ball joint page
http://www.pavementsucks.com/tech-article-5.html
Old Jan 29, 2011 | 01:17 AM
Flipzslick's Avatar
Flipzslick
Today I got everything off excePt the ball joints( have to pick up a press in the morning). I'm replacing the ball joints, u joints, hubs, and brakes. While I'm in there. Parts went to bad about $350 it came apart fairly easy had a few speed bumps. My inch drive set my 1 11/16 socket would not fit down in the hub to take of the axle nut so off to tractor supply. For abot $30. I got 3/4 in dr. T bar, 1 11/16 socket 12pt 14mm 3/4-1/2 adapter and my threaded rod and nuts to Put on my 14x3, not to bad I don't think. My other bump was it looked like some one tried taking off the upper ball joint cotter Pin and broke it and tried taking offf the nut with it still in . That was a pain in the ... But I got it. Now to tackle the u joints tonight at work on the press.....
Old Jan 29, 2011 | 07:01 AM
Flipzslick's Avatar
Flipzslick
Ok I cracked a ear on the pass. Side axle shaft 
Old Jan 29, 2011 | 10:16 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Why? I replace lights as they burn out. Damn, talk about being OCD **** compulsive.
Old Jan 29, 2011 | 08:01 PM
Truedge's Avatar
Truedge
It happens that if one headlight goes out the opposite side headlight will be soon to burn out. I have heard that this is caused by a voltage use differential, but I think it's just because of the consistency of bulb technologies and that they are most likely replaced at the same time. If one goes, the other is soon to follow. besides, I can always tell an old bulb from a new one by looking at the brightness and that kinda bugs me.
Old Jan 30, 2011 | 07:08 PM
Flipzslick's Avatar
Flipzslick
Ok guys the jobs done! Took me long enough. Lol only took three trips to the parrs store to get the right/good upper ball joint.
Old Jan 30, 2011 | 11:13 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I've replaced the driver's side headlamp in my truck and just one taillamp in 5 years of ownership.
I'll chalk up that logic to being an Old Wive's Tale.
