transmission will not shift into overdrive
zman17,
I took my truck to a mechanic and he told me the problem was in my transmission so I went to my transmission guy and he said it was electrical and it was problem with my computor. I know a guy who works at a salvage yard and I am going to see if he can get me one to try, do they have to be the same year and model of truck or will one from a 2 wheel drive work?
thanks
thanks
Albeit I am new here, I am a skilled mechanic, but I have a 46RE that is giving me the fits. Having the issue of not shifting into OD. Took the lock up and OD solenoid block out and found that it was no good. I replaced it and it still doens't shift into OD. Where is this fuse or circuit that routes power to the proper solenoid located? The truck is a 2001 Ram 1500 V6
Does the OD lite go on and off when you push the button? Just curious.
