brights problem
Old Feb 5, 2011 | 01:26 PM
  #21
Check and see if there are any grounds up in that area. I think there may be one that goes from body, to battery terminal, or some such.
Old Feb 5, 2011 | 01:27 PM
  #22
ricer's Avatar
ricer
I have a similar problem with my newly purchased 2006 Ram. When I pull the dimmer switch to go from low beams to high beams the headlights will brighten but not stay on bright, they will just go back to low beams. But ocassionaly they will got to high beams when I pull the switch but then I can't get them back to low beams. Is this just charactistic of needing a new dimmer switch?
Old Feb 5, 2011 | 01:28 PM
  #23
More than likely.
  #24
dvowicker's Avatar
dvowicker
yah theres one that goes tp the top of the fender
Old Feb 5, 2011 | 02:07 PM
  #25
zman17's Avatar
zman17
Retired Moderator - RIP
You might also want to remove the covers from the steering column and check the wires in there if you have a tilt wheel.
Old Feb 5, 2011 | 05:11 PM
  #26
dvowicker's Avatar
dvowicker
Okay I got a new mf switch still mo help I've decided I'm goin to run new wire what gauge should I use for the headlights?
