help
Old Feb 1, 2011 | 05:58 PM
mr freeze's Avatar
mr freeze
I tried googling "mumbo-jumbo" scanner and i came up with nothing,is that a brand name or category??
Old Feb 1, 2011 | 06:11 PM
dhvaughan's Avatar
dhvaughan
fuel sync times the injectors to the cam... in something like micro-degrees..using a very expensive scanner to set the computer.
that might be a problem later, but its not his most immediate problem.
if the OP has spark on the other 6 plugs and no spark at all on those 2 plugs, then he has a simple wiring problem. the spark from the coil is distributed by the rotor through the cap.
if he has no spark on any plugs, then its something more complicated.
