Abs/ Brake Light
Old Feb 1, 2011 | 12:12 PM
DodgeTheFather Ramthe Daughter's Avatar
Default Abs/ Brake Light
so ive been reading on here about how to fix the abs and brake light mine has been on for awhile and the brakes are very sensitive and lock up very easy today i reaplaced the Rear Wheel Speed Sensor and disconnected the negative on the battery but the abs and brake lights are still on and the brakes are still the same what else can i do
Old Feb 1, 2011 | 12:15 PM
Silver_Dodge's Avatar
Silver_Dodge
Does your speedometer work?
Old Feb 1, 2011 | 12:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure the brake line above the gas tank is not leaking.
Old Feb 1, 2011 | 02:40 PM
BamaRam97's Avatar
BamaRam97
Check your wheel cylinders for leaks! That was my problem. You have to actually take the drum off to be positive.
Old Feb 1, 2011 | 03:01 PM
loneriderty's Avatar
loneriderty
Default check your fuses
your fuse could be blown for brake light mine had that problem
Old Feb 1, 2011 | 08:24 PM
the speedo works fine and no leaks in the line ill check the fuse box and the wheel cylinders tommorow thanks for the suggestions
Old Feb 2, 2011 | 09:40 AM
chastain90's Avatar
chastain90
Mines also on. Have you checked your abs sensor thats what I was told to do. I just havent yet.
Old Feb 2, 2011 | 09:51 AM
zman17's Avatar
zman17
Double check the line above the tank while you check the cylinders, it is hard to see and even the smallest pin hole can cause the issue. The fluid does not have to be leaking every where.
