which timing chain ?
Old 02-05-2011 | 07:12 PM
lumpydump's Avatar
lumpydump
Default which timing chain ?
getting ready to purchase a timing set but which one? whats the advantage of an OEM chain set versus a double roller? i understand the different key ways are for changing your timing but not really interested in doing that just want the best chain and sprokets.
thanks
Old 02-05-2011 | 07:32 PM
aim4squirrels's Avatar
aim4squirrels
Double roller is supposed to be more sturdy and a bit less parasitic.
I used a jp performance chain that was recommended to me for durability and ease of setting a cam. It was a very tight fit though.
Rollmaster make a pretty beefy chain that a few ford guys I know swear by.
Old 02-05-2011 | 07:39 PM
dhvaughan's Avatar
dhvaughan
i used the stock replacement for about $35-40. Cloyes C-3072.
Old 02-05-2011 | 09:12 PM
lumpydump's Avatar
lumpydump
ok thanks i have all the bolts off the timing chain cover and i havent removed it yet cuz all the threads i read said "careful not to tear the oil pan gasket" is there any special trick to remove cover? like straight up or at an angle so i dont tear the oil pan gasket
Old 02-05-2011 | 09:35 PM
dhvaughan's Avatar
dhvaughan
lift slightly. if there is any resistance, slide a screwdriver or putty knife under the edge of the timing cover, and ON TOP of the oil pan gasket. slide it back and forth a little to unstick the gasket.
edit - if the timing cover is stuck to the front of the block, give it a whack with a rubber hammer.
Old 02-05-2011 | 10:40 PM
aim4squirrels
I ripped the Oil pan gasket last time I removed the TC. I just patched it with some oil resistant RTV. Might be sloppy, but it worked just fine. beats the heck out of removing the oil pan.
Old 02-06-2011 | 02:02 AM
matty675's Avatar
matty675
get a double roller set with tensioner
Old 02-06-2011 | 02:20 AM
RamSport97's Avatar
RamSport97
I used this set for the price and durability
http://www.summitracing.com/parts/CCA-2103/
Old 02-06-2011 | 02:28 AM
J415's Avatar
J415
Why??
Old 02-06-2011 | 09:46 AM
03neonSE's Avatar
03neonSE
I use a timing chain and gear set from Mopar. Its one thing I will not get cheap with.
Quick Reply: which timing chain ?
