E fan wiring HELP Im an IDIOT
Old Feb 5, 2011 | 07:27 PM
97Rampowerhouse's Avatar
97Rampowerhouse
Question E fan wiring HELP Im an IDIOT
Ok guys time for the stupid question of the day! I have a e fan set up im putting in my truck and I must be having a brain fart here. Are the fans suppose to be wired to blow air toward the radiator or suck the air thru. Im thinking its sucking the cool air thru but I need someone elses opinion.
Old Feb 5, 2011 | 07:34 PM
dodgeram07's Avatar
dodgeram07
suck thru(puller),,,, blowing on the motor
Old Feb 5, 2011 | 07:37 PM
97Rampowerhouse
ok thats what I thought Thank you!
Old Feb 5, 2011 | 07:38 PM
draco8494's Avatar
draco8494
yup x 2 pull thru blowing on the enigine...
Old Feb 5, 2011 | 07:44 PM
candymancan's Avatar
candymancan
Wouldnt be to effective while driving if it was pushing the air coming in from driving.
Old Feb 5, 2011 | 08:12 PM
J415's Avatar
J415
Actually, there are two types of fans, pushers and pullers. Pushers are meant for installation IN FRONT of the rad or cooler. Pullers are meant for installation BEHIND the rad or cooler.
Old Feb 5, 2011 | 08:34 PM
drewactual's Avatar
drewactual
yup...
I have both a pusher and a puller.. offset..
It should be said also that the same fan will not PUSH as much air as it will PULL.. Mine are rated at 2750cfm pulling, but only 2400cfm pushing.. If you only have room/power for one, it makes a lot more sense to pull with it, rather than push..
Old Feb 5, 2011 | 09:07 PM
97Rampowerhouse
so the one you traded me is a puller right? by the way did you get your headers?
Old Feb 5, 2011 | 09:20 PM
J415's Avatar
J415
Yes, they are pullers. I was just trying to make a point in my last post, thats all. Haven't received the headers yet. Decided to wait 'till Monday. I'm just to busy with work. BTW, were did we leave off regarding the gaskets?
