difference in v10s
Old Feb 7, 2011 | 09:04 AM
buck6680's Avatar
buck6680
Default difference in v10s
I have a 95 3500 with the v10 that I want to swap engines in. I came across a good 96 v10, reasonably priced. What are the differences between the two? I notice most salvage yards are saying 94/95 only will fit in my truck.
Any advice would be greatly appreciated.
thx,
Old Feb 7, 2011 | 09:23 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Probably the sensors. 94-95 = OBD1 while 96 up is OBD2. Swapping sensors or the whole manifold may solve that issue. Works for the v8's anyway.
Old Feb 7, 2011 | 06:49 PM
buck6680's Avatar
buck6680
Thanks for the reply. Any more detailed information would be appreciated. I don't want to buy a motor that I won't be able to use.
Thanks to all.
Old Feb 8, 2011 | 08:25 PM
buck6680's Avatar
buck6680
Anyone know of anything else? So I can buy a 96 model and install it in a 95 truck and it will work?
thanks,
Old Feb 8, 2011 | 08:44 PM
V-10s aren't quite as common as the 8's, so, not quite as much info out there for 'em.
Old Feb 9, 2011 | 07:49 AM
buck6680's Avatar
buck6680
If I understand correctly, then all I would need to do is to swap the sensors over from my 95 engine to the 96 and install it? It should run correctly?
Thx,
Old Feb 9, 2011 | 08:38 AM
I would do coil packs, and ignition module as well. Basically, anything that a wire plugs in to.
Old Feb 9, 2011 | 08:55 AM
dipsherry's Avatar
dipsherry
yeah i would have to agree... obd1 as you truck is has less sensors and computer controlled stuff... than a obd2 truck i would have to agree with heyyou and just say swap all your sensors a.k.a anything that a plug goes into was a good quote. I am just stating what i know about the v8 and assuming but its a pretty educated guess
Old Feb 9, 2011 | 08:20 PM
buck6680's Avatar
buck6680
Thanks to all for the info. I'll give it a try.
