Rear axel movement
Old Feb 7, 2011 | 01:42 PM
velocity37's Avatar
velocity37
Default Rear axel movement
The rear wheels on my 99 dodge ram 5.9L 4x4 have a tiny bit of play. If i grab the tire and push and pull on it as hard as I can there is some movement on the axel not much but enough that you can hear a clank. I was replacing the shoes on it the other day and I could see the axel move as I pushed and pulled on it. I know there should be some movement there but they do make noise on large bumps. Any ideas? C clips??
Old Feb 7, 2011 | 01:51 PM
Half ton truck? Normal. Should be an eighth of an inch or so...
Old Feb 7, 2011 | 01:56 PM
velocity37's Avatar
velocity37
yah its a 1500 , I know there should be some movement but the clunking noise of them moving in and out???
Old Feb 7, 2011 | 01:57 PM
They are held in by c-clips, so, the clunk isn't unexpected either.
Old Feb 7, 2011 | 02:09 PM
velocity37's Avatar
velocity37
should i just leave it ?
Old Feb 7, 2011 | 02:10 PM
If it doesn't move very much, and doesn't make crunching/grinding noises, don't worry about it.
Old Feb 7, 2011 | 03:36 PM
Hahns5.2's Avatar
Hahns5.2
Normal, don't worry about it.
