Still Losing Oil After Plenum Fix
does your motor, leak oil?
see mine leaked when driving,, i would drive home park the truck, 10min later nice size pool of oil,,, sit over night start it up, move it 20 feet park it no oil leak
what happen was the the vavle cover was lose, oil would work it way down after driving awhile,,,
but any way 105 not the best, sum people say restore engine additive works great for get compission back up,, but im not a fan of additives
Alright here goes! Cant find any new leaks with the dye, after wiping the bottom near the oil pan no oil has dripped, so i guess theres no leaks! As of the last few days ive had real bad smoke on startup after the truck has been sitting, so theres obviously something wrong with the valves, even after i just did the valve seals! Any more input? Its still using a quart every 200-250 miles, the smoke on cold start stops after 5 mins too....
Rear main seal can cause a lot of loss in a small amount of time.
have you done a dry/wet compression test? (not that the test would find buggered oil control rings.....)
Gotta be goin' somewhere.
Wet test will tell you about rings. To test valves, need to do a cylinder leakdown test. If the numbers came up significantly with the wet test, rings are on their way out. (and that would explain oil consumption.)
Pressure didnt increase on wet test! The smoke on cold start is getting worse, and i did notice some smoke getting on the highway today, but it only happened at about 3500 rpms, the engine was revving hard, then as soon as it shifted it stopped.....Im clueless, has to be a head issue
