Old Aug 14, 2015, 02:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
Brake problem, huge problem! 2001 Ram
Old Jan 5, 2013 | 08:16 PM
Norman Calkins's Avatar
Norman Calkins
Default 98 dodge ram 1500 5.9 flooding out
I have a 98 dodge ram 1500 with a 5.9 and it is flooding really bad and won't start. I'm putting new plugs in it and have cleaned the iac motor. Checked the fuel pressure and its good. Any ideas on what could be causing it.
Old Jan 5, 2013 | 09:35 PM
Tommy Francetic's Avatar
Tommy Francetic
hey make shr your calipers are on right you can put them on the worng side and bleed the **** out of it and as soon as you turn the truck on the peddle go.s mush . bleeder must be pointing up words if down words air will get stuck in the top of the caliper. i did this one time when my truck was in 1000 pec and i put them on the wrong side
Old Jan 5, 2013 | 09:58 PM
Erm, what does this have to do with brakes???? I don't see anything relating to them at all....
For the flooding problem, if you push the gas pedal to the floor, will it start and run?
Old Jan 5, 2013 | 11:05 PM
Hjhf1500's Avatar
Hjhf1500
Tommy is right, try switching the calipers. That happened to me before.
Old Jan 6, 2013 | 06:37 AM
Tommy Francetic
Old Jan 6, 2013 | 06:40 AM
Tommy Francetic
norman this thred is for a brakes not your flooding problem you need to move your post and make a new thread and moderator delete my double post plz
Old Feb 9, 2013 | 11:20 PM
Matthew Morris's Avatar
Matthew Morris
Default Brake pressure!!!!
Yes, I have a 2001 Dodge Ram 1500 4x4. I have replaced everything under the front end of the truck, including tie rods, calipers, spindles, etc. The front brakes have no pressure what so ever. The rear brakes r holding, to the best of my knowledge. I have even replaced the rear wheel cylinders, and master cylinder. I have pressure when the truck is not running, but as soon as I crank the truck I have lost all pressure on brakes. Someone please help this is the only vehicle I have to get my family around. What is the problem and how can I fix this problem?
Old Feb 9, 2013 | 11:32 PM
gdstock's Avatar
gdstock
Do you realize this is an OLD thread?
\ (we need an animated grave digger icon...
Should have started a new thread.....
Do you get brake light or ABS light?
Old Feb 10, 2013 | 08:47 AM
Matthew Morris
Yes the calipers are on the right way. My step dad and I can't figure out why we have no pressure on the front brakes. Would unplugging the battery reset the RWAL module?
Old Feb 10, 2013 | 09:58 AM
No. It won't.
Is the brake lite in the dash on?
