Which suspension lift ???????
Old Feb 8, 2011 | 01:14 PM
mikentiff's Avatar
mikentiff
Default Which suspension lift ???????
Ok I am wanting to purchase my lift as soon as my tax return gets here. I am just unsure which kit it best and the most complete. Also do I need anything else that the kit does not have.
http://www.topguncustomz.com/Store/G...iview=25474016
http://www.topguncustomz.com/Store/G...view=133989476
http://www.topguncustomz.com/Store/G...view=133989376
http://www.topguncustomz.com/Store/G...view=200793306
Old Feb 8, 2011 | 01:24 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Which ever one come's with at least 4:10 gears
Old Feb 8, 2011 | 01:29 PM
mikentiff's Avatar
mikentiff
I know I gotta change my gears haha
Old Feb 8, 2011 | 02:36 PM
zman17's Avatar
zman17
Do everything in the right order and you'll spend a lot less money in the long run.
Old Feb 8, 2011 | 02:54 PM
TheBigRedOne's Avatar
TheBigRedOne
The first one.
Old Feb 8, 2011 | 03:05 PM
mikentiff's Avatar
mikentiff
Do I need anything else for the lift or does that kit include everything I need ?
Old Feb 8, 2011 | 03:09 PM
mikentiff's Avatar
mikentiff
Will the 4.10's hurt or help my mpg ?
Old Feb 8, 2011 | 03:30 PM
TheBigRedOne
Maybe brake hoses. Otherwise you should be fine. Lifting period is going to kill your mileage, gears won't really help offset that.
Old Feb 8, 2011 | 03:54 PM
PurplDodge's Avatar
PurplDodge
The first one if it had new springs for the rear.
Old Feb 8, 2011 | 04:58 PM
slider15004x4's Avatar
slider15004x4
I would go for the first one with the add a leaf upgrade instead of the blocks, also add sway bar drop brackets, track bar relocation bracket and drop pitman arm. Also get a new set of lower control arm cam bolts from the dealership. You are going to break the old ones taking them off. Make sure you get them from the dealership because all the other ones the eccentrics are too small.
Last edited by slider15004x4; Feb 8, 2011 at 05:06 PM. Reason: additional info added.
