2001 1500 5.9L missing/backfiring
Old Feb 8, 2011 | 04:36 PM
spur_ride's Avatar
spur_ride
Default 2001 1500 5.9L missing/backfiring
Heres my issue. i Had a bad coil wire so i replaced coil wire, coil, plugs, plug wires, and cap and rotor( hadnt replaced those in a long time) and drove fine for a trip (120+ miles round trip) and no it seems to be missing or back firing when i get it up to anything above an idle. this truck is starting to make me want to push it off a cliff and im stuck on hat reason it would be missing like this.
Old Feb 8, 2011 | 05:35 PM
Recheck your wires, make sure they are all seated good, and routed per the TSB that you can find in the faq section here. (there is a TSB thread.....)
If that doesn't solve it, pull a couple plugs, and see what they look like.
