Plenum Plate
Old Feb 8, 2011 | 11:51 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default Plenum Plate
Strangely enough I couldn't find the answer to my question in a search, however I know it's been covered dozens of times.
Roughly how large of a piece of aluminum do I need to make the plenum plate?
Old Feb 8, 2011 | 11:58 PM
kazslo's Avatar
kazslo
https://dodgeforum.com/forum/2nd-gen...imensions.html
Old Feb 9, 2011 | 03:01 AM
99dodge318's Avatar
99dodge318
i would just trace the oem piece of steel on the sheet of aluminum and cut.
id send you my factory belly pan but i beat the hell out of it with a hammer after i replaced it!
Old Feb 9, 2011 | 07:24 AM
dhvaughan's Avatar
dhvaughan
if you wanted to make the plate up ahead of time, you can buy a gasket and use it as a pattern. you'll need the gasket anyway come swap time.
from champion....
7 1/4" x 16" rectangular dimensions at the widest and longest points. I used a skil saw with a carbide blade to cut mine out, and then a bandsaw to trim it.
