Which Steering Stabilizer
Old Feb 10, 2011 | 11:07 AM
Big Guz's Avatar
Big Guz
Ok, check em out.
As far as I can tell, where the two shocks meet back to back they are supported by a plate that mounts to the main axle. and the far end by the driver side just gets extended farther over to make room for the other shock and mounted to the same bar (not sure what it's called, inner tie rod?) Does this sound correct?
Old Feb 10, 2011 | 11:08 AM
No Problem.
Probably..... Different makers do things a bit differently, but, they all serve the same purpose. Dig for pics. That is gonna be your best bet. Or, if you get really lucky, find someone near you that has a similar setup.....
Old Feb 10, 2011 | 01:59 PM
Big Guz's Avatar
Big Guz
Does anyone know of a place near Merrillville, IN that does these enough to maybe have em in stock or be able to give me a good description of how and where they mount?
Old Feb 10, 2011 | 04:36 PM
TheBigRedOne's Avatar
TheBigRedOne
You don't need a steering "stabilizer" period. One of the greatest automotive scams ever. All they do is add load to the steering rack and make more work for the pump.
