brake and abs
Old Feb 10, 2011 | 10:43 PM
jcfuzzdog29's Avatar
jcfuzzdog29
Default brake and abs
My ABS has been on since I bought the truck and today I was driving it and my brake light came one what could be the problem. When I turn the key off and back one the brake light goes away but comes back in a little bit. I have a 95 2500 v8 with 158 thousand on it. Thanks
Old Feb 11, 2011 | 10:16 AM
2 or 4 wheel abs?
Old Feb 11, 2011 | 10:30 AM
99dodge318's Avatar
99dodge318
when my abs and brake light popped up i replace the rear abs sensor, its on top of the rear differential.
when this sensor goes out you lose you speedo and odometer too, along with your torque converter lock-out
Old Feb 11, 2011 | 10:31 AM
His is a 95, so, he has a speed sensor elsewhere in the driveline.
Old Feb 11, 2011 | 11:03 AM
jcfuzzdog29
im not sure if i have 2 or 4 wheel abs i got the truck in late november realy didnt have time to check stuff im new to trucks to .
Old Feb 11, 2011 | 11:27 AM
Take a look at one of your front wheels. If you have 4wal, there will be a sensor with a wire, if it ain't there, you have RWAL, and the sensor on the diff is likely the problem.
Old Feb 11, 2011 | 11:43 AM
jcfuzzdog29
ok thanks for the help you guys are alot nice on here thne the subaru forums lol.
Old Feb 11, 2011 | 02:17 PM
jcfuzzdog29
It looks like i might have 4 wal abs im not real sure what the wire would look like but it looks like all 4 wheels have it
Old Feb 11, 2011 | 02:38 PM
stands2p's Avatar
stands2p
post a pic of the drivers side engine compartment.then ill tell ya if you have front abs.its that simple.go figure.
Old Feb 11, 2011 | 02:55 PM
jcfuzzdog29
hope this is ok
