anyone put 5.2 cam in 5.9?
Old Feb 15, 2011 | 11:46 PM
Adobedude's Avatar
Adobedude
Like others have said...Get a custom grind for your 1.7s, but that will mean new springs and custom length push rods.
Push rod length will have to be dead nuts on since the HS rockers you have are non adj.
Stock springs can barely handle a stock cam, especially with some miles on them...And more spring pressure raises the chances of the stock two piece valves snapping the heads off the stems.
Old Feb 16, 2011 | 02:39 AM
97tn4x4's Avatar
97tn4x4
If I understood the guy I talked to at Hughes about the whiplash cam in the magnum motor I put in my Mazda pickup the centerline of the cam has to due with the relation of the lobes to the the center of the cam. The factory cam is a 114 degree LSA. Dropping the lsa and more lift and duration gives that nice aggressive idle. Now I may not be 100% right, this is just how I interpreted what he told me.
Old Feb 16, 2011 | 09:26 AM
Adobedude's Avatar
Adobedude
You're right, lope at idle comes from tight lobe seperation & large duration, like the 548/547 236/242 @ 108º installed at 104º in my Dakota.
Old Feb 16, 2011 | 11:21 AM
97tn4x4's Avatar
97tn4x4
Is that .050 duration or advertised?
Old Feb 16, 2011 | 12:43 PM
Adobedude's Avatar
Adobedude
.050 duration
Old Feb 16, 2011 | 02:56 PM
BigRedRam95's Avatar
BigRedRam95
So the lsa of this cam is 112 right but what does the intake centerline mean it says it is 108
http://www.compcams.com/Company/CC/c...?csid=659&sb=2
Old Feb 16, 2011 | 03:41 PM
Hows about a little reading material.
Old Feb 16, 2011 | 03:49 PM
BigRedRam95
I have read that I just like to hear it from someone so I know I do everthing right.
Old Feb 16, 2011 | 09:27 PM
97tn4x4's Avatar
97tn4x4
Originally Posted by Adobedude
.050 duration
That's a thumper right there.
Old Feb 16, 2011 | 09:41 PM
97tn4x4's Avatar
97tn4x4
.050 duration
