Heater problems
Old Feb 13, 2011 | 10:44 AM
JBULLFROG187's Avatar
JBULLFROG187
Default Heater problems
So I have a 2001 Ram 1500. The heater only works on the high setting. Dont know if its the switch or the blower or???? Any ideas?
Old Feb 13, 2011 | 11:13 AM
zman17's Avatar
zman17
Retired Moderator - RIP
There is a resistor on the heater box down by the blower motor that commonly goes bad.
Old Feb 13, 2011 | 11:25 AM
90w250's Avatar
90w250
Zman is right,more than likely it is the blower motor resistor if it works at some settings and if it does not work on any setting then I would look toward the switch.
Old Feb 19, 2011 | 02:52 AM
MajorTomFoolery's Avatar
MajorTomFoolery
I just fixed the same problem. $50 bought me anew blower motor resistor. It took less than five minutes to swap it out. 2 phillips screws under the passenger side dash revealed the ceramic burnt and falling apart. All fixed.
Old Mar 5, 2011 | 12:28 AM
lseven's Avatar
lseven
Hi, I have a similar (identical) problem with an 07 Dakota. It actually has less than 25,000 kms on it and all worked fine when I last drove it regularly. It's been parked mostly for almost a year but driven or run every few weeks.
At any rate a dealer told me the blower AND sensor are shot and it will be $550 to fix!!! This makes no sense to me as the blower clearly works but only on high and I don't understand what 'sensor' needs to exist in this set up. It seems more likely a problem with the switch or as said in this thread the resistor.
My question is, does anyone know how easy a fix this would be in a 07 Dakota versus the 01 Ram the OP refers to? I suspect the set ups are similar in the models but may have changed quite a bit over 6 model years.
Any help/advice would be appreciated.
Old Mar 5, 2011 | 12:33 PM
MajorTomFoolery
Look under the glove box for two Phillips screws with a couple wires ran to it. Unplug the wires, take out the screws. If the ceramic looks toasty or the contacts melted. Get a new one
Old Mar 7, 2011 | 06:29 PM
JBULLFROG187
Thanks for the help everyone!! Got it fixed!
