broken header bolt & stuck drums
Old Feb 16, 2011 | 07:44 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by aim4squirrels
Put the rear axle on blocks or jacks, remove the tires, replace one lug nut loosely threaded. Hop in cab and turn truck over. Push gas lightly in drive and slam the brakes. The hubs will be loose.
The above is usually prefaced with the statement: "Here, hold my beer for a minute."
Originally Posted by J415
Originally Posted by VWandDodge
If the drum backing plate has a slot in it then you can turn the adjusters to pull the shoes inward.
Not all drums have a slot to access the adjuster. I know mine don't.
The key word in my statement is, "IF".
Old Feb 17, 2011 | 09:01 AM
dipsherry's Avatar
dipsherry
thanks guys i will just try to tap the drums loose... as far as the header bolt i had a pair of vice grips on it and tried to turn no luck.. it is in the head good and i dont have acess to a welder
Old Feb 17, 2011 | 09:22 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Use heat -- and lots of it. It'll be a bear to remove so be patient. Also, you may want to use anti-seize on the new bolts when you bolt the headers back on.
Old Feb 17, 2011 | 09:27 AM
dipsherry's Avatar
dipsherry
i am a youngin so i dont quite have a large tool selection. best heat source i have would b a butane torch.. would that be affective?
Old Feb 17, 2011 | 09:36 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
It might, but you may want to spend a couple of bucks and get a propane torch. Many people suggest MAPP gas, but I don't like it because it doesn't last very long. The propane torch will be an investment as it's always handy for heating stubborn fasteners.
