Seafoam!!
Old Feb 16, 2011 | 05:26 PM
offroadjosh's Avatar
offroadjosh
Default Seafoam!!
Decided to change my oil today, and sea foam happen to be on sale. Bought two cans onf it, and pout a full one in the gas tank and then half in the oil and half through the brake booster. Stalled it out with the last little bit and let it sit for a good 20min. Came out started it up and blew smoke all over and then changed the oil. All i can say is WOW!!! I have wayyy more power now. Very happy with it, hope it helps my mpg too.
Old Feb 16, 2011 | 05:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'd avoid putting it in the oil if I were you. Regular oil changes is good enough.
Old Feb 16, 2011 | 06:34 PM
1995crow's Avatar
1995crow
Okay so I have heard about the oil thing to not out it in there but. My real question is do you pour it in the intake?
Old Feb 16, 2011 | 07:25 PM
zman17's Avatar
zman17
Pull the hose off the brake booster and slowly pour it in the hose.
Old Feb 16, 2011 | 07:56 PM
bekins01ram's Avatar
bekins01ram
I read somewhere once in this forum, that using the PCV valve hose from the top of the valve cover supposedly spreads the seafoam better. I seafoamed my truck using the brake booster last summer, and it smoked quite a bit...2 days later i did it again with the pcv and it smoked like crazy. I just seafoamed it 2 days ago with pcv again, and it worked like a charm. Idle is smooth, doesnt drop to near dying RPMs while slowing to a stop, and just feels a bit better in the pedal. I'd suggest using the pcv valve hose to suck it into the intake, instead of brake booster. It worked better for my truck.
Edited: Just thought I'd add, If i remember correctly, the reason given for the pcv hose being better was that it was smaller in diameter, compared to the hose from the brake booster, so it atomized the seafoam and spread it better. I back this up with 0 scientific facts, except it worked better in my case
Old Feb 16, 2011 | 08:35 PM
crazzywolfie's Avatar
crazzywolfie
putting it in the pcv valve will put the sea foam in your engine oil and not in the engine like the brake booster line.
Old Feb 16, 2011 | 08:46 PM
zman17's Avatar
zman17
No it won't. The hose is connected to the intake just like the booster.
Old Feb 16, 2011 | 08:48 PM
PurplDodge's Avatar
PurplDodge
Depends on what end you grab.
Old Feb 16, 2011 | 09:00 PM
bekins01ram
Yeah, in my post, I said to suck it through the pcv valve "hose"...the one that goes to the intake...I just kinda figured that was a given, since you're trying to clean the intake and such. I never have put it in my oil, even though it says it's safe. Oil changes should be enough if you do them properly.
Old Feb 17, 2011 | 12:05 AM
99dodge318's Avatar
99dodge318
so half in the tank and half in the pcv valve tube, let it STALL, and sit for 20 mins?
is that right?
how many miles should you drive it before you change the oil? sorry ive never used seafoam. thinkin about using it before my next oil change.
