low idling
Old Feb 17, 2011 | 11:18 PM
TwistedCage's Avatar
TwistedCage
Default low idling
i can not figure out why my truck is idiling so low. from 0 to 1 it is just under half and it dies out on me when i go to stop or put it in gear
Old Feb 17, 2011 | 11:27 PM
UnregisteredUser's Avatar
UnregisteredUser
If it's otherwise running well it could be the IAC, the TPS, or even the pre-cat oxygen sensor. Got any other symptoms like decreased gas mileage, loss of power, noises?
Old Feb 18, 2011 | 09:51 AM
TwistedCage
well i am getting around 11 mpg but i am ridding on LT285/75/16D. My pre cat 02 has been firing slow but been that way sence i had the truck and the idle problem just started
Old Feb 18, 2011 | 09:54 AM
TPS or IAC then.
Old Feb 18, 2011 | 10:16 AM
TwistedCage
how hard is it to find out which one it is with out buying both
Old Feb 18, 2011 | 10:20 AM
Twisted Metal's Avatar
Twisted Metal
You can pull the TB and try clean the TPS, and IAC. and clean the TB too. There is a tread on how to do it. (There's that SEARCH option again). Some good contact cleaner works well. For what it is worth, normal idle on my truck is 800 rpm.
Old Feb 18, 2011 | 10:29 AM
TwistedCage
the normal idle for the truck is 800 i am about 400 or 500
