Rear bearing preload
Old Feb 18, 2011 | 06:52 PM
jrp267's Avatar
jrp267
Default Rear bearing preload
On the dana 80 I installed new seals in the hubs. According to this page http://dodgeram.org/tech/specs/axle/286RBI_specs.html The nut that preloads the bearings is set to 120 to 140 ft lbs. Does that sound right? The spin but seem tight. Not chunky tight but dont spin free. Although it is 17 degrees and it is 80/ 90 but let me know if this seems right. Thanks
Old Feb 18, 2011 | 07:54 PM
Your link is coming up rather odd.... certainly not a tech article.....
Old Feb 18, 2011 | 08:07 PM
jrp267's Avatar
jrp267
hmm and I checked it
Old Feb 18, 2011 | 08:09 PM
jrp267's Avatar
jrp267
Apparently thier domain registration expired. Cause it was there this morning but now its gone. Well does anyone know the torque spec? for the rear axle nut?
Old Feb 18, 2011 | 08:56 PM
Specs from the 01 manual say 120-140 ft/lbs, then Loosen the adjustment nut 1/8 of-a-turn to provide 0.001-inch to 0.010-inch wheel bearing end play.
Old Feb 18, 2011 | 10:24 PM
jrp267's Avatar
jrp267
thanks I guess I will back them off an 1/8
