add-a-leafs
Old Feb 19, 2011 | 06:26 PM
BackwoodsRam's Avatar
BackwoodsRam
Default add-a-leafs
hey guys i blew a lift block the other day and i figured it would be a good time to go to 6 inch lift leaf springs, ut a 600 dollars a set its a little out of my price range. i did find a set of 4 inch add a leafs from superlift for less than 200 shipped and i was wondering what were the pros and cons of addaleafs
Old Feb 19, 2011 | 10:54 PM
99dodge318's Avatar
99dodge318
how did you manage to blow a lift block? aren't they cast steel?
got a pic? i like to see carnage as long as its not on my rig! lol
Old Feb 19, 2011 | 11:01 PM
BackwoodsRam
no carnage, i caght it before it completly blew off but the back half of it is missing, turns out that blocks are the weak link if ur truck get air born.
Old Feb 20, 2011 | 09:06 AM
Silver_Dodge's Avatar
Silver_Dodge
Pros of an AAL: Easy way to lift the rear, easy to install, helps supports loads better (less sag in the back), looks stock
Cons of an AAL: Stiffer ride, requires new u-bolts (usually have to have them custom made), doesn't flex that great
That's all I can think of right now.
Old Feb 20, 2011 | 09:39 AM
TheBigRedOne's Avatar
TheBigRedOne
This thread makes me smile.
Piece together a leaf pack from some used Deavers, or K20 leaves. It will be 100 times better then any add-a-fail, will ride much better, won't look like ***, and will probably be about the same price.
