Don't know
Old Feb 20, 2011 | 09:36 AM
mooseguy's Avatar
mooseguy
Default Don't know
I have replaced just about everything too do with the code 43...wires..plugs..ignition coil...cam and crank sensors still same problem eveytime I turn around the shop mechanic is telling me too get this or that. I have spent enough already approx 1000 dollars on this issue now I would like too really know can a code 43 be a bad fuel pump or a blocked cat if so how can I find out without paying through the nose .the truck do make alot of popping noise when she loses power and there is a few slight hesitations and the rpms change slightly a few times before lost of power ...
Old Feb 20, 2011 | 09:38 AM
What year is your truck? What engine?
and..... what is code 43?
Old Feb 20, 2011 | 09:45 AM
mooseguy's Avatar
mooseguy
1996 dodge ram with a 5.2 engine ... code 43 in the hanes repair manual states ...peak primary circuit not acheived with maxium dwell time haven't the slightest clue what that means ...ty
Old Feb 20, 2011 | 09:52 AM
Ok, from what I can find, a fair number of these problems relate to plug wire routing. Try re-routing your wires according to the TSB, see if that helps.
