synethic vs regular?????
Old Feb 21, 2011 | 04:53 PM
  #21
Annihilator_X9's Avatar
Annihilator_X9
So I just looked in the 2001 Service Manual. On page 17 Dodge Recommends 5w-30 Synthetic for below 0°F temperatures.
Old Feb 21, 2011 | 04:55 PM
  #22
PurplDodge's Avatar
PurplDodge
52,000 miles all on synthetic is different than 140,000 on dino then another 40,000 on synthetic. No restore or flush.
  #23
BigRedRam95's Avatar
BigRedRam95
So I should not run seafoam for 10 min idling then drain the oil? I was going to do this when I change the oil next time.
I also run synthetic and change it every 6000mi
Old Feb 21, 2011 | 05:36 PM
  #24
zman17's Avatar
zman17
Retired Moderator - RIP
Do you have some problem with the engine or the oil?????? If not, leave it alone and do regular oil and filter changes. If you WANT a problem, start adding all kinds of crap to your motor for no good reason.
Old Feb 21, 2011 | 05:45 PM
  #25
BigRedRam95
I just thought it would help clean the motor.
Old Feb 21, 2011 | 05:49 PM
  #26
matty675's Avatar
matty675
never add ANYTHING to your oil, despite what some people may tell you to do
Old Feb 21, 2011 | 06:09 PM
  #27
zman17's Avatar
zman17
It's clean enough if you do regular oil changes.
Can you say clogged oil pump screen?
Old Feb 21, 2011 | 06:10 PM
  #28
PurplDodge's Avatar
PurplDodge
So I shouldnt put honey in my oil to seal up my valve cover leaks? Dang!
Old Feb 21, 2011 | 06:14 PM
  #29
matty675's Avatar
matty675
HAHAHA NO! what have you been smoking??
maple syrup works MUCH better!
Old Feb 21, 2011 | 06:17 PM
  #30
BigRedRam95
When I ran reg oil I changed the oil and filter every 3000 now with the synthetic I change the oil and filter every 6000.
