synethic vs regular?????
Old Feb 21, 2011 | 08:09 PM
  #41
CPTAFW163's Avatar
CPTAFW163
Originally Posted by BigRedRam95
So do you think I am still ok at 6000?
no. The viscosity will still be there, but it will still have LOADS of carbon in it making it sludgy.
Pay no attention to thermal breakdown and viscosity, it is all about clean oil and regular changes.
Things that kill an engine:
1. Dirt (in the oil, FI, and cooling system)
2. Heat
3. Lack of oil
Just change the oil with dino oil and the filter every 3K and you will be fine. Get good oil filters. I just go with synthetic because I can splurge for the extra 8-10 bucks and you usually get a really good oil filter with it as well.
Autozone has 5 qts of castrol edge and a K&N filter (13 dollar filter) for 32 bucks. I was gonna try it but the two autozones in my town don't carry castrol edge. SO I got syntec.
Old Feb 21, 2011 | 08:13 PM
  #42
candymancan's Avatar
candymancan
I heared K&N filters suck from alot of people online. I'll never buy one, the Purolator Plus filters (the yellow ones) tho is what i use, heared good things about them being one of the better filters.
Old Feb 21, 2011 | 08:22 PM
  #43
PurplDodge's Avatar
PurplDodge
You heard wrong. They are probably the best oil filter you can get at a parts store, but also the most expensive at $13-$14 a pop.
WIXs and NAPA Golds for me, you just cant beat the prices on them too.
Old Feb 21, 2011 | 09:06 PM
  #44
lastrights's Avatar
lastrights
i devoplop a colasped lifter i think using sythetic oil. not totally sure if the oil that caused it though, but from what ive read i could see thats the reason ?
Old Feb 21, 2011 | 09:15 PM
  #45
PurplDodge's Avatar
PurplDodge
Do an oil analysis.
Old Feb 21, 2011 | 09:41 PM
  #46
pavement_hater's Avatar
pavement_hater
Originally Posted by CPTAFW163
it breaks down the same rate. But here is something that DOES NOT change:
The carbon in your oil. It does not matter how well it holds its vscosity, you are still running with DIRTY oil.
If you change your oil and filter every 3 K, it does not matter what oil you use. I splurge on synthetic for preference. and 27 bucks every 3-6 months is not that bad for me.
Most oil testing will show that if you are changing out synthetic that soon, you are wasting money. No matter what you believe. It does not break down at the same rate. Also just because it may look dirty does not mean it is bad. It can have a dirty look and still be just as lubricating as when it was new. Oil testing can also prove that.
Originally Posted by matty675
HAHAHA amsoil claims 10,000 miles!
I run 20k with full synthetic Amsoil with no..... notice I said no issues with oil. Did the same in my Wrangler with no issues. For what its worth I could be doing the 25k they claim.
2. Heat
3. Lack of oil
Have never had a sludge issue running synthetic, even at the 20k mile interval. It does not sludge like regular oil.
Old Feb 21, 2011 | 10:18 PM
  #47
RamSport97's Avatar
RamSport97
My 318 has had synthetic its entire life as well, 122k. When I replaced the plenum at 110k there was no crust in the valley, it was spotless. When I replaced the valve covers with Mopar Performance covers at 118k there was no crust and was spotless. When I replaced my timing chain 300 miles ago there was no crust and was spotless. I agree with CPTA, replace your oil every 3k (even if it will last 20k) along with a quality filter, and you will have no crusting issues.
Old Feb 21, 2011 | 10:36 PM
  #48
dodgeram07's Avatar
dodgeram07
s,hit im supposed to change my oil?
any who, i belive dino hold better viscosity than synethic tens to thin out at higher temps,,, but that me
sum synethics do not have detergent like sum dinos
i think till think it gets back to reguler oil changes and heat of the motor breaking thing down
Old Feb 21, 2011 | 10:41 PM
  #49
pavement_hater
Originally Posted by dodgeram07
**** im supposed to change my oil?
Only if your plenum is not blown. If it is, it will change itself.
Old Feb 21, 2011 | 10:47 PM
  #50
dodgeram07's Avatar
dodgeram07
dam true story, when mine was blown i couldnt keep oil in it,,, dirty or clean oil
