Old Aug 4, 2015, 07:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Oxygen Sensor Questions?
Old Feb 22, 2011 | 12:14 AM
Powder$kier30's Avatar
Powder$kier30
Default Oxygen Sensor Questions?
Hello fellow Dodge heads. My truck is a 2001 Dodge Ram 1500 Sport 4door, 4x4, 5.2L 318. I have searched everywhere on here and in my Haynes manual to find out how many O2 sensors are on my truck and can't find a credible answer. I am under the impression that there are 4 total, one pre Cat and one post Cat on each side. I am confused when I read "only in California" etc. I live in Idaho so I don't have emission guidelines as strict as CA, but we still have them. Before I make this post too confusing, I will post my questions orderly as follows:
1. How many o2 sensors does my truck have?
2. What are the best brand of o2 sensors? I assume NTK?
3. What are some tricks to removing the old sensors if they are stuck when I go to remove them? High heat treating with a torch?
4. What part number NTK sensors do I need? I am slightly confused understanding the difference between A/T (Calif.) and M/T rated sensors and what thes abbreviations stand for at NTK's website: http://www.ngksparkplugs.com/part_fi...uv/results.asp . Please help.
My orignal symptoms are the classical stalling/cutting out during excelleration. It goes away if I let off and after engine is warm. I understand that it can be a clogged CAT, plenum gasket, etc., but I am pretty sure it is only faulty o2 sensor/s. I will start there. I don't think the CAT is clogged and I thing I have been blessed to not have plenum gasket failure. I will be sure to post my end result but I need to know how many sensors to purchase before I do the job. One last thing, my gas mileage is horrible right now and has gotten excesively worse along with the stalling, I am excited to see an increase in fuel mileage. Thank you in advance for all who read this and reply.
Old Feb 22, 2011 | 12:38 AM
Mad_Scientist's Avatar
Mad_Scientist
Should have 2 unless it was manufactured to be sent to and sold in cali.
All of the symptoms you cited indicate a clogged cat. A bad o2 would set a code and turn on your cel (a clogged cat does too, but it doesnt happen until its REALLY clogged); you sure your plenum is good?
Old Feb 22, 2011 | 12:40 AM
UnregisteredUser's Avatar
UnregisteredUser
Should be two on a Federal emissions vehicle. The best bet, though, is to crawl under the truck and look.
NTK or whatever the dealership hands you.
Soak 'em down with a good quality penetrating oil overnight, and if they hang up use mechanical shock to fracture the rust. Heat might work, but where they're located I'm hesitant to go with a flame.
If you've got a Federal emissions truck, go with the Federal emissions parts. If you can't find any other indication of the original destination of the truck, get a build sheet from Chrysler (the quick way is to visit a dealer with your VIN handy) to find out. It's a safe bet that if the truck wasn't originally sold in California it's a Fed truck.
Old Feb 25, 2011 | 07:40 PM
TLars's Avatar
TLars
Hey guys - I was amazed of how easy it was to get mine out to check it. It looks like a rust color. I'm at 106k. I think its original - should I go ahead and replace or save the $70 for something else for now?
Old Feb 25, 2011 | 07:44 PM
grox's Avatar
grox
Yeah, my O2 sensor didn't even require a wrench to remove it.
I would replace it, check Rockauto.com. It ought to be around $40 for an NTK, at least on my OBDI truck it was that much.
Old Feb 25, 2011 | 08:03 PM
TLars's Avatar
TLars
I see there is an upstream and downstream. My cat is a 2 in / 1 out and the sensor is kind of in the middle. ???
Old Feb 25, 2011 | 08:05 PM
grox's Avatar
grox
The upstream is more important, and that is the one in the cat.
Old Feb 25, 2011 | 09:44 PM
Mad_Scientist
Dont fix what aint broke.
I just rolled over 177k on my original ones, never had a problem. They look rusty on the outside because of heat, humidity, mud, etc. If you pull one, the probe is likley soot covered, but just fine.
Save the money
Old Feb 25, 2011 | 09:46 PM
Mad_Scientist
edit: <deleted> double posted
Old Feb 25, 2011 | 09:47 PM
grox's Avatar
grox
The service life of an O2 sensor is between 60K and 100K miles (depending on type), so it should be changed.
