Pace setter
Old Feb 24, 2011 | 01:51 AM
Lemunman's Avatar
Lemunman
Default Pace setter
I just bought pace setter headers shorty direct fit need help everyone seems to be bashing them does anyone like them or have good luck with them ? Or can help me on how o put them on properly so no leaks
Old Feb 24, 2011 | 11:37 PM
dodgeman2289's Avatar
dodgeman2289
i have shorty ones i had to rearrange the bolts on the drivers side becuase they wouldnt tighten down on one or two bolts. as for leaks i got leaks in them 2 times blew out 2 gaskets. untill i had my mechanic change the pattern again cause it was causing leaks.. now 4-5 months down the road everything is great!
Old Feb 24, 2011 | 11:52 PM
97Rampowerhouse's Avatar
97Rampowerhouse
Buy the locking bolts to save hassles down the road. You will thank yourself
99dodge318's Avatar
99dodge318
i installed my pacesetter shorties in my drive way in about 3-4 hours and 12-14 beers.
i bought them used but new, if that makes sense. the guy bought them and never installed them and lost the hard-ware.
so i purchased them for $100 and also bought some stage-8 locking header bolts, and felpro metal gaskets.
ive never had a problem with them other than having to re-torque them after the first 200 miles.
Old Feb 24, 2011 | 11:53 PM
99dodge318's Avatar
99dodge318
damn powerhouse your slightly faster than me
Old Feb 24, 2011 | 11:55 PM
97Rampowerhouse
lol you did beat me on the beer count lol
Old Feb 25, 2011 | 12:23 AM
pcfixerpro's Avatar
pcfixerpro
In addition to the above, SOAK SOAK SOAK those bolts before you try to remove them. Mine soaked every day for a week before even attempting to pull them. Also, if I had to do it again, I would probably keep the center studs, but I pulled them for the stage 8 header bolts. The studs will help you line everything up if you opt to keep them. You can hang your gasket, and hang your header in place instead of dancing in the engine bay trying to get everything lined up.
Here is a pic of the pacesetters shortys that have been on for a few years. Only picture I have and was taken back in august.
Old Feb 25, 2011 | 12:27 AM
97Rampowerhouse
+10 on soaking the bolts I broke 5 of them off in the block and had to drill and helicoil mine
Old Feb 25, 2011 | 12:28 AM
J415's Avatar
J415
I thought the whole point of the stage 8 bolts was that you didn't have to re-torque?
Old Feb 25, 2011 | 12:33 AM
97Rampowerhouse
Yup Yup!
by the way J415 how did those headers turn out for you?
