Starting out - 1996 5.9 1500
Old Feb 24, 2011 | 02:22 PM
FireDodge's Avatar
FireDodge
Question Starting out - 1996 5.9 1500
Trying to find some relatively cheap mods to do to it to give it a little more kick. Currently, I have a small Magnum brand chip that doesn't do a whole lot. Also have a K&N filter, but not the whole cold air intake. It has new plugs and wires. The previous owner had straight exhaust that Y'd into duals, but I threw a Thrush Welded muffler on it because my neighbors were gettin angry. Has 315/75/R16's now, getting a lift soon. I would love to have more power, but am on a pretty tight budget. Thanks.
Old Feb 24, 2011 | 02:28 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Simple:
Hughes plenum plate fix
high flow cat
50mm throttle body
full tune up
sct tuner
4:56 or 4:88 gears
Notice how nothing on the list is cheap?
Power ain't cheap.
Happy modding.
Old Feb 24, 2011 | 02:45 PM
FireDodge's Avatar
FireDodge
I was thinking of getting a 52mm throttle body, since I have a friend who can get them relatively cheap. The plenum plate is a definate must though. Thanks.
Old Feb 24, 2011 | 02:56 PM
stands2p's Avatar
stands2p
remove the chip crap and do the crank sensor mod it is free and it does help if done correctly.diy throttle body free if you have the skills and tools.14x3 old school air cleaner 30 bucks.like to see a stock height 1500 with 315's(which is killing performance).got pic's......
Old Feb 24, 2011 | 03:09 PM
FireDodge's Avatar
FireDodge
i would upload photos if I could, but every time I create an album, there's no 'Upload' button anywhere, I have an album in my profile i made a while back with the 315's
Old Feb 26, 2011 | 12:38 PM
Bam Bam's Avatar
Bam Bam
what is the crank sensor mod
Old Feb 27, 2011 | 04:10 AM
Saleenster's Avatar
Saleenster
Ditto ? ?
Old Feb 27, 2011 | 05:27 AM
stands2p's Avatar
stands2p
you remove the crank sensor and cute/slot the two bolt hole in able to slide the sensor down towards the oil filter.if slotted completely open you increase base timing 4*.its a worth wild free mod if you dont have a tuner.dont do both.like any tuner a 180 stat may be needed
http://www.bionicdodge.com/Download/...th%20Flash.pdf
Old Feb 27, 2011 | 01:59 PM
CPTAFW163's Avatar
CPTAFW163
Hey,
too bad you didn't have a 5.2, because i would mail you the MOPAR PERFORMANCE PCM for fifty bucks.
Old Mar 14, 2011 | 01:24 AM
FireDodge's Avatar
FireDodge
I added a pic to my signature now, so this is stock height with 315's
